Thread: Odd Color Change when Testing for Chlorine
    Default Odd Color Change when Testing for Chlorine
    I am using a full testing kit with 5 drops of R-0001 DPD Reagent #1 and 5 drops of R-0002 DPD Reagent #2 to test for chlorine.
    When I put in the reagents they immediately show a FC reading of about 1.5 to 2.0. Within about 2-3 minutes the water in the test tube turns a strange light gray purple. I've never had this happen before. Could it be my chemicals have gone bad? They are about six months old.
    Alk - 100
    CH - 180
    PH - 7.5
    I have an "endless" pool that is only about 2800 gallons. I use standard Chlorox bleach to sanitize and the occasional Borax or Baking Soda to adjust. I do have to add Muriatic Acid periodically but not more than every other week. The pool is covered all day and I am the only swimmer so I keep the chlorine relatively low. There is any stabilizer in the water right now. The only other chemical I have added is a water clarifier.
    Default Re: Odd Color Change when Testing for Chlorine
    I have seen the LaMotte reagents turn that color on the FC test after standing a few minutes. LaMotte says the FC should be read within 30 seconds of performing the test. From the reagent numbers I see you are using the Taylor reagents. I have not experienced that with them but I am going to test tomorrow and let the test sit to see if it develps the same off color I have seen with the LaMotte reagents. Might be normal, especially if the DPD solution is getting old.
    I bought new reagents and my chlorine readings are much higher and it doesn't turn the funny color. Interesting, because the reagants weren't very old.
    Anyways.............now I know what to look for.
    Thanks!
    Mickey
    DPD reagent #2 does have a shorter shelf life than the rest of the reagents in the test.
  1. new water...overnight color change
    By PFPAM in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-26-2007, 12:41 PM
  2. Color change?
    By SeanB. in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 11-19-2006, 10:25 AM
  3. Determining color change for TA
    By MrSparkle in forum DPD-FAS based testing
    Last Post: 07-15-2006, 08:29 PM
  4. PS200 Chlorine Chart - Am I color blind?!
    By sharknj in forum DPD-FAS based testing
    Last Post: 06-12-2006, 08:44 PM
  5. How much does liquid 6% Chlorine change PH
    By smallpooldad in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-24-2006, 06:51 PM
