Thread: New Salt System Questions
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: New Salt System Questions
    Salt is not generated, chlorine is generated by the cell using the salt you add to the pool. What are your chlorine levels? If the FC is remaining constant, then you can assume the SWCG is operating well. Can you test your salt in another way to see if the SWCG reading is accurate?
    Jun 2013
    Sorry...yes I knew that chlorine is generated from the salt. Well, it appears that the system has shorted out. They came today to evaluate. They said it could have had a lightning strike, or a power surge...we haven't had a storm or any power surges in quite some time. He said he would send it back under warranty, but not sure they will cover it. There is only one little place on the plug that goes into the box that looked burned. How could just one little spot have had a problem. If it were lightning or a power surge, wouldn't the entire plug be burned? Anyway...they will replace it and I am praying the manufacturer will honor the warranty...60 days of use I sure don't want to purchase another one.
    PF=5; 23K gal IG kidney vinyl pool, Triton II Sand Filter, Whisperflow VS Pump, Taylor 2006 kit, Jacuzzi/Carvin Saniclear 40 SWCG
    Jun 2013
    Another problem with the salt system tonight...the no flow light is lit...what does that mean other than the system isn't producing chlorine. I love the water with this system, but it seems that a lot can go wrong. This system is only a little over a month old. I still believe that the box mounted on the house gets really hot during the day. Any tips about care and maintenance for salt systems?
  1. Questions about switching to a salt system
    By Norman in forum --cleanup--
    Last Post: 05-04-2015, 03:20 PM
  2. traditional salt chemical system or go with the Mineral Springs salt system?
    By Thehamms in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-25-2014, 12:46 AM
  3. How much salt for Intex 16 x 48 with 54601EG Salt Water System (no manual)
    By QiingGuy in forum Intex-type Pool Setup & Operations
    Last Post: 06-19-2014, 01:44 AM
  4. Considering these upgrades...new VS pump and salt system....few questions
    By YearZero in forum Pool Equipment & Operations
    Last Post: 03-11-2014, 09:26 PM
  5. Nature Two Pool System Versus Salt System
    By billie in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-03-2012, 01:27 PM
