welcome to the world of pool water maintenance...its not nearly as hard as you may think. First thing i will tell you....there is NO need to go anyplace else for info on your pool than right HERE. Not the neighbor...and not the pool store...these guys have it down cold.
I would NOT add any borax...you want your PH down while you airate to lower your TA. You may in fact be adding muriatic acid to it to keep it low during aiaration...but for now just keep the filter running 24/7 with the jets breaking the surface...
next get bens kit....your FC/TC numbers are a little out of wack and I suspect the kit more than the water. You can't have a TC number that is lower than your FC number...so you should read read read and understand what the numbers mean...and soon the reall experts will be along to guide you to clear clean safe water.
good luck with it!!
