Results 1 to 10 of 75
Thread: Cloudy Please help
    Jul 2013
    Northern Illinois
    Default Re: Cloudy Please help
    You must not like math....!
    For 8.25%:
    12 minus (-) current tested FC = #ppm needed.
    Then
    #ppm needed times (x) 3.5 cups of bleach = how many cups to add.
    There are 4 cups to a quart and 16 cups to a gallon.
    mrszaff is offline Registered+ Thread Analyst mrszaff 0
    May 2010
    New York
    I haven't added the bleach yet ...and its only 5% not 8, but anyway after adding everything I have so far, my reading is not even close to 12 yet.
    I love math, lol ...I teach it all day to 10 year olds.
    I really do appreciate your help, I'm just getting anxious because I have been fighting this cloud for 10 days now. I will post my new numbers tonight or tomorrow. Thanks again!
    16x32' rectangle 19K gal IG vinyl pool; bbb; jacuzzi sand filter; jacuzzi pump; 8hrs; Taylor 2000; utility water; summer: none; winter: vinyl / water bags; ; PF:6.3
    Jul 2013
    Northern Illinois
    Hahaha about teaching math!
    Since we know this:
    If your chlorine is 10%: add 3C for every 1ppm increase you need
    If your chlorine is 12.5%: add 2C, 3oz for every 1ppm increase you need
    Then 5% would be 6C or 1.5Q
    I don't know what you were doing for some of the last 10 days, but if you brush the pool and KEEP your FC at 12 (or even a tad over), by testing and adding as often as you can, your pool WILL clear.
    EDIT: I just reread the thread. I neglected to suggest that you remove the pucks. Let's get them out if they're still in there.
    May 2010
    New York
    Ok thank you! I will remove the pucks and post numbers tomorrow. Thanks again
    May 2010
    New York
    my numbers this morning fc=1.5 cc= .5
    I can make out the drain its just not crystal clear yet, but its an improvement for sure. I will keep adding bleach and I will vacuum today.
    I haven't let anyone use the pool, what do you think? thank you!
    Jul 2013
    Northern Illinois
    Glad your CC's are coming down; that's good. If you can see a swimmer in trouble, you can swim at FC of 12 but wear old suits. Keep it at 12 as often as you can.
    May 2010
    New York
    at 4pm ...getting better, fc=5.5 cc=.5, adding more bleach
    Jul 2013
    Northern Illinois
    Maybe you can check in a half hour and make sure you hit 12.
  1. From cloudy green to cloudy blue
    By Dydylynn in forum Dealing with Algae & Slime
    Last Post: 06-10-2012, 05:09 PM
  2. Cloudy ,Cloudy,Cloudy... for a week now.
    By uwinsome in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 05:55 PM
