Re: CH Questions
Several observations...
First, using trichlor pucks will cause your CYA levels to rise. Not a problem now but it can become one. If you want to use a puck to maintain your FC occasionally that should be fine as long as your CYA levels are low. Once they rise above about 50 ppm I would not use pucks anymore. Be aware that they can cause your pH to drop.
You are using a N2 and many people with them run the FC at .5 to 1.5 ppm. I notice you are not. N2 is a copper/silver system. The main 'advantage' to adding metal ions to the water is to allow running lower FC levels. (I have 'advantage' in quotes because this can very easily and often does become a dangerous disadvatage of not having enough residual sanitizer in the pool to keep the water safe.) The copper comes from copper sulfate and the silver from silver nitrate..The N2 system is just an erosion feeder for the copper and silver compounds. for more info on copper and silver read this thread
http://www.poolforum.com/pf2/showthread.php?t=98
My advice is to save money on the N2 replacement cartridges and take the system out of your plumbing (or at least run it without a cartridge). It really doesn't do all that much good for all that it costs to run. SAve yourself the $160 to $220 a year the replacement cartridges will cost you!
The only way to get to know how much bleach your pool will take to keep it sanitized (and how much acid or borax it will take to keep the pH in line) is by testing these 2 parameters daily and keeping a record of how long they are in the proper range and how much of the proper chemicals it takes to get them back in range when they go out. It's a learning curve and you soon reach a point where you know that if you put in x amount of bleach every n days and y amount of acid every m days your pool will be fine under normal usage conditions. Do a bit of work on it now and you will have much less later once you know what is normal for your pool. Your bleach usage will be best once your CYA is in the 30-50 ppm range. Then shoot for 3-6 ppm FC and shock to 15 ppm when you get CC or cloudy water.
Finally about MPS or oxyshock. It will not remove CC. the idea is to get a residual of it in the pool to burn off organics before they form CC. MPS will test as CC on a DPD test and as TC on an OTO test. This makes it very hard to know if you have CC or residual MPS in the water. It is also not as good an oxidixer as chlorine and can have adverse affects on the pH. It has no true advantage in a chlorine pool. It is best used with bromine where it will actually reactivate the bromine bank into hypobromous acid...the active sanitizer in a bromine system. MPS is NOT a sanitizer so if your chlorine is too low adding MPS will NOT sanitize the water!!!!!!
