Thread: Bubbles in pump basket?
    mas985's Avatar
    Pleasanton, CA
    Default Re: Bubbles in pump basket?
    What is the filter pressure for each valve setting? Skimmer only, MD only and Both
    Mark
    Pressure on my e 65 de filter with valve in middle is16psi.when just skimmer its15psi and just main drain its13psi.
    mas985's Avatar
    Pleasanton, CA
    When the valve is set at 100% skimmer, do the bubbles get worse?
    When at 100% skimmer, check the skimmer to see if it is sucking in air from a vortex.
    If so, it could be low water level or a stuck weir
    If not, it might be a leak in the line
    Mark
  1. Getting Air Bubbles in Skimmer Basket
    By DixieGirl in forum --cleanup--
    Last Post: 10-04-2015, 11:23 AM
  2. Air bubbles in pump basket
    By FormerBromineUser in forum Pool Equipment & Operations
    Last Post: 09-17-2014, 12:18 AM
  3. Pump basket lid stuck
    By cmcq in forum Pool Equipment & Operations
    Last Post: 10-02-2010, 08:25 PM
  4. air bubble in pump basket
    By mbar in forum Pool Equipment & Operations
    Last Post: 06-02-2008, 09:25 PM
  5. pump will only prime when basket it out
    By ScottsdaleSwim in forum In-Ground Pool Construction and Repair
    Last Post: 10-23-2006, 10:52 PM
