Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Odds-n-Ends (P)
Clearance
--cleanup--
Chlorine in Bromine Pool
FAQ
register
Results 1 to 1 of 1
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
05-15-2016
12:28 PM
#1
cgconnor36
View Profile
View Forum Posts
Junior Member
May 2016
Ohio
Is it OK to use liquid chlorine in a bromine pool for spring startup?
Quick Navigation
--cleanup--
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Help with Fanta sea pool
Hello, I am looking for info on a Intex Ultra Frame 22' x 52" pool liner replacement
Chlorine Shock okay in Bromine Pool?
By MineIsBromine in forum Pool Chemicals & Pool Water Problems
1
Last Post:
07-18-2014,
05:07 PM
Bromine pool - no detectable bromine.
By ptrdvs44 in forum Pool Chemicals & Pool Water Problems
3
Last Post:
07-17-2012,
05:58 PM
Bromine and Chlorine
By jtagscott in forum Pool Chemicals & Pool Water Problems
1
Last Post:
06-09-2012,
10:18 PM
Shocking a Bromine pool - can I use chlorine shock
By Needzo in forum Using Chlorine and Chlorinating Chemicals
12
Last Post:
05-21-2010,
07:39 AM
Bromine to Chlorine
By jrv331 in forum Using Chlorine and Chlorinating Chemicals
9
Last Post:
05-30-2006,
09:26 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
