Somehow, air is slowly getting into your pump when it is off. If there are there any tiny air bubbles in the return water, that's a good indication that you have a leak between the skimmer and pump. If you have a water leak between the pump and return, that will let air in when the pump is off. A good place to start checking for leaks is the pump seal. Do you have a check valve in the system?
