Thread: Total Mess - Vacuum Suggestions
    Oct 2011
    Southern New Jersey
    Default Total Mess - Vacuum Suggestions
    I hope I can be laughing about this soon but not laughing now. When removing the cover I lost grip and all the debris that collected on top fell into the pool. (I usually pull to to the deck and shop vac it before lifting but it slipped thru my hands!) It looked like the smoke monster for from "Lost" as it slowly turned my clear water to a greenish mess! It is filled with tiny leaf particles that are too small to skim with a net. I am in for LOTS of vacuuming. Anyone ever have to clean a mess like this? What do you suggest?
    Steve Romo (6700g AG, Cartridge Filter)
    Jul 2013
    Northern Illinois
    Default Re: Total Mess - Vacuum Suggestions
    You may not be laughing now... But your phrasing sure tickled me into a giggle! Never had that issue, but my thought is to let it settle and vacuum ever so slowly.
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    I don't cover my pool, I find it doesn't save me any work in the spring. If you chlorine levels are up, everything should settle to the bottom and your water clear up, then vacuum to waste. Easy peasy. Love the "Lost" reference. Smoke monster. Awesome.
    Oct 2011
    Southern New Jersey
    Correct, it did clear up the next day and the debris settled into clumps on the bottom. Still lots of vacuuming! 5 passes so far and it's 80% clear. I've posted before asking for vacuum tips cause I sometimes lose suction halfway thru and don't realize it. It seems more productive with this kind of problem to "dab" the vacuum brush over each clump instead of brushing along the floor which seems to scatter the debris instead of sucking it up. Always looking for vacuum tips from the experts! Thanks for the replies!
    Jul 2013
    Northern Illinois
    Go slowly. With time, you will get to "feel" when the vacuum head starts to lose suction. Then you can clean the filter and start again.
    Jul 2013
    Northern Illinois
    You're losing suction because the filter is dirty.
    May 2014
    I divide my pool into quarters and clean out the leaf basket, pump basket and backwash IF NECESSARY. With a cartridge filter, it will be necessary, but with my sand filter, I try not to backwash too often. In the case of a sand filter, of flow is good and you don't have an algae problem, don't backwash.
  1. mess after vacation
    By Fiveattripp in forum Pool Chemicals & Pool Water Problems
    Last Post: 10-07-2014, 01:54 PM
  2. Vacuum Suggestions for AGP
    By devandmic in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-13-2012, 04:28 PM
  3. What a mess in my pool
    By Pool_Mike in forum Pool Equipment & Operations
    Last Post: 09-25-2006, 11:11 AM
  4. Don't want to mess up the pool
    By doriec in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 01:15 AM
  5. help...have I got a mess
    By tazt60968 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2006, 11:07 AM
