Thread: Total Mess - Vacuum Suggestions
    Oct 2011
    Southern New Jersey
    Default Re: Total Mess - Vacuum Suggestions
    Correct, it did clear up the next day and the debris settled into clumps on the bottom. Still lots of vacuuming! 5 passes so far and it's 80% clear. I've posted before asking for vacuum tips cause I sometimes lose suction halfway thru and don't realize it. It seems more productive with this kind of problem to "dab" the vacuum brush over each clump instead of brushing along the floor which seems to scatter the debris instead of sucking it up. Always looking for vacuum tips from the experts! Thanks for the replies!
    Steve Romo (6700g AG, Cartridge Filter)
    Jul 2013
    Northern Illinois
    Go slowly. With time, you will get to "feel" when the vacuum head starts to lose suction. Then you can clean the filter and start again.
    Jul 2013
    Northern Illinois
    You're losing suction because the filter is dirty.
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    I divide my pool into quarters and clean out the leaf basket, pump basket and backwash IF NECESSARY. With a cartridge filter, it will be necessary, but with my sand filter, I try not to backwash too often. In the case of a sand filter, of flow is good and you don't have an algae problem, don't backwash.
  1. mess after vacation
    By Fiveattripp in forum Pool Chemicals & Pool Water Problems
    Last Post: 10-07-2014, 01:54 PM
  2. Vacuum Suggestions for AGP
    By devandmic in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-13-2012, 04:28 PM
  3. What a mess in my pool
    By Pool_Mike in forum Pool Equipment & Operations
    Last Post: 09-25-2006, 11:11 AM
  4. Don't want to mess up the pool
    By doriec in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 01:15 AM
  5. help...have I got a mess
    By tazt60968 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2006, 11:07 AM
