After 5 seasons, pump will not run this spring. When switched on it just hums and moves no water. Saw many posts to repair, but have a few questions first. Obviously to manually turn impeller I have to drain it ... can the pump run when dry??? I never did that before. During winter I had to disconnect and reconnect the ground wire at the pool frame. Can an interrupted ground wire cause this? Can the outlet be bad or would that result in no power at all? ... If unable to repair I will replace. Not savvy on electrical lingo... it has a unique plug and receptacle. It is round with three curved prongs - one of which has a notch. You insert and spin slightly to lock into plug. What is this type of plug called? Receptacle has "20A 125V" engraved. Do all new pumps have this same type of plug and meet the same Amps / Volts? Thanks in advance!
