Thread: Need a second set of eyes on my plan
    Bosch232 is offline Registered+ Thread Analyst Bosch232 0
    Aug 2012
    Nebraska
    Default Need a second set of eyes on my plan
    FIRST DAY:
    Opening the pool, water was more green than ever. I netted off the heaviest from the surface, and vacuumed the dirty bottom to waste. Still very cloudy. Filtering/backwashing 24/7.
    SECOND DAY:
    Brought the PH down to 7.3. It had risen to 8.0+ over winter. Total alk is about 160. Shocked to pool up to 10 ppm. Brushed pool walls. Filtering/bw 24/7.
    THIRD DAY:
    Rain overnight. PH still 7.3. Chlorine 7 ppm. Cloudiness not improving. Added a little more chlorine before leaving for work. Backwash was pretty brown this morning. Filtering/bw 24/7.
    Is the cloudiness *for sure* an algae problem? Am I on the right track? I'm resisting the urge to drain and refill, but the amount of chlorine and testing materials I'm consuming will equal the cost of new water pretty soon. (Cost isn't really my motive, mostly I'm just being impatient.)
    Opinions please.
    16x32 Oval AG vinyl pool; Media Master sand filter; 1.5 hp 1 speed pump; 10 hrs; Rural utility water; Taylor K-2006
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: Need a second set of eyes on my plan
    Is it cloudy but not green anymore? Can you see to the bottom? I would say you are on the right track. Have you done the overnight test?
    Aug 2012
    Nebraska
    It's cloudy and no, I can't see the bottom.
    Second round of tornados tonight, so that's not helping.
    It's sort of blue-ish green.
    Very slight improvement in clarity today.
    Mainly I just want to know if I'm fighting algae or something else.
    Jul 2013
    Northern Illinois
    What is your CYA level? Please check that against the best guess chart to make sure you are targeting the correct "shock level".
    26K gal 20x40 rectangular IG vinyl pool; Apr 2014: New pump, liner, auto-cover, & water; Pentair Whisperflo 1HP pump; Pentair Trition sand filter; Cover/Star CS-500 auto cover; Taylor K-2006C; OTO
    May 2014
    Agreed with FBU. If its green, its algae, and if you are not getting you chlorine up high enough according to the best guess chart, you'll be spinning your wheels.
    Aug 2012
    Nebraska
    DAY FOUR:
    Significant improvement in clarity. pH = 7.4 Chlorine = 7.0 ppm Backwashing twice a day, less brown each time.
    Definitely going the right direction.
    I havent tested cya because I ran out of testing fluid and forgot over the winter.
    I did treat for 12k gallons so it's gotta be in the ballpark.
    I'll let you know when I can test it.
    Aug 2012
    Nebraska
    I nailed it: 5.5 ppm vs 6.5 ppm last night, 7 hours ago.
    Another big scoop of chlorine, on the way...
  1. Eyes burn
    By Bosch232 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-30-2014, 11:07 AM
  2. My eyes, my eyes
    By shadowman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-09-2008, 07:57 PM
  3. Is it a stain, or my lying eyes?
    By steveinaz in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-23-2007, 08:56 PM
  4. Red eyes
    By PaulE10 in forum Dealing with Alkalinity and Calcium
    Last Post: 09-09-2006, 04:09 PM
  5. Chlorine-red eyes
    By Palmer in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-24-2006, 04:15 PM
