Results 1 to 10 of 58
Thread: Getting Calcium Levels Right
    Aug 2014
    Chelsea AL
    Default Re: Getting Calcium Levels Right
    I probably haven't let the water circulate long enough but after 2 pounds and roughly 1.5-2 hours I'm dead on 7.2. I say dead on but as you know testing without sunlight is hard. Under my kitchen floresciants it looks like 7.2
    Virginia
    Quote Originally Posted by jmarcum View Post
    Good. Retest tomorrow morning if possible to see if that's accurate. If it is 7.2, at least you're out of the "danger zone".
    Jul 2013
    Northern Illinois
    ^+1
    Aug 2014
    Chelsea AL
    Should I bother trying to raise my TA? It's currently 40.
    Virginia
    If your pH stays stable and your CSI is good, then I wouldn't worry about your TA number. I suspect though that you may end up needing to raise it some.
    Aug 2014
    Chelsea AL
    PH holding steady at 7.2
    When I plug all my numbers into the calculator the CSI say -0.91 -0.52. That seems to be indicative of something bad but I'm not sure what I'm supposed to do to fix it.
    Parker, CO
    I'll throw in my two cents for what it's worth.
    From what I was told (by chem geek), your CSI should be between -0.3 and +0.3. I try to shoot for the middle of all the recommendations on that page. For your setup I would probably go with:
    FC - 3 or 4
    pH - 7.6
    TA - 80
    CH - 300
    CYA - 40
    Assuming no SWCG and with a temp of 65 your CSI would be -.11 which the calculator will tell you the water is balanced. If your water ever got up to 100, your CSI wold be +.19 which would still be balanced. Right now with the current numbers you've input, "Corrosion of plaster is likely". If you go the other way and your CSI is +.3 or greater "Scaling is possible".
    I played with that calculator quite a bit to figure out what would be best for my spa and for the pool. Seems to be working out pretty well for me.
    Figure out what works best for you and then try to hold those numbers.
    Hope I didn't over step my boundaries. Good luck!
    36'x20' Freeform, IG - 13k gal, Spa - 800 gal, Diamond Brite, Intelliflo VS pump, TR-140C sand filter, Mastertemp 400k BTU heater, 2HP Whisperflo pump (waterfall), Pool Pilot Digital RC-42 SWCG, K-2006 Test Kit
    Virginia
    Quote Originally Posted by Toybuilder View Post
    FC - 3 or 4
    pH - 7.6
    TA - 80
    CH - 300
    CYA - 40
    I would add to be careful not to go too low on the FC. 3 is at the lowest end recommended for your CYA; it leaves no room for error. I'd shoot for mid recommended range, so about 5ppm.
    Aug 2014
    Chelsea AL
    FC - 3 or 4
    pH - 7.6
    TA - 80
    CH - 300
    CYA - 40
    I don't understand how to change the CSI though. Are you saying if I hit all the all numbers the CSI will just fall in line?
    Virginia
    CSI is calculated based on the numbers you out in. You can play around with different chem levels and you will see CSI change. For example, try the numbers Toy suggested and see how it affects the CSI number.
  1. Calcium Hardness Levels for Heater
    By bottomcat in forum Pool Equipment & Operations
    Last Post: 06-01-2015, 07:25 AM
  2. Cloudy water in pool with high calcium levels
    By elocicero in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-08-2013, 11:39 PM
  3. Pool Calcium levels
    By beachfrontpool in forum Dealing with Alkalinity and Calcium
    Last Post: 08-22-2012, 11:39 AM
  4. Higher Calcium Levels & Stable pH
    By chem geek in forum The China Shop
    Last Post: 08-03-2008, 07:58 PM
  5. Low calcium levels, plasticizers in vinyl liners, leaching cobalt from fibergalss?
    By waterbear in forum Dealing with Alkalinity and Calcium
    Last Post: 04-21-2006, 08:07 PM
