Results 1 to 10 of 58
Thread: Getting Calcium Levels Right
    Aug 2014
    Chelsea AL
    Default Re: Getting Calcium Levels Right
    I lowered the ph....now it takes 6 drops of R-0006 to get up to 7.0.
    TA: 40
    CH:250
    CYA:35-40
    Virginia
    Up to 7???
    I hope you didn't drop your pH below 7 (7.2 is the lowest I would go). Doing so risks damage to your pool.
    Aug 2014
    Chelsea AL
    Yes, as in its under 7.0. Trying to determine how much baking soda I need to add now. :-(
    Aug 2014
    Chelsea AL
    Seems like it's actually borax I need not baking soda. Is that right? I don't know how to calculate this because I don't know what my ph actually is (since it was completely off the charts low)
    Virginia
    Quote Originally Posted by jmarcum View Post
    Yes, you use borax to raise pH.
    Here's a tool you can use to calculate doses
    http://www.troublefreepool.com/calc.html
    You may have to initially estimate your pH and go from there. Try raising pH a little at a time instead of trying to do it in one shot.
    Aug 2014
    Chelsea AL
    Thanks, I have their iOS app. From an estimated 6.5 it says add just over 5 pounds. How about if I add 2.5 pounds and test again tomorrow?
    Virginia
    That sounds reasonable.
  1. Calcium Hardness Levels for Heater
    By bottomcat in forum Pool Equipment & Operations
    Last Post: 06-01-2015, 08:25 AM
  2. Cloudy water in pool with high calcium levels
    By elocicero in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-09-2013, 12:39 AM
  3. Pool Calcium levels
    By beachfrontpool in forum Dealing with Alkalinity and Calcium
    Last Post: 08-22-2012, 12:39 PM
  4. Higher Calcium Levels & Stable pH
    By chem geek in forum The China Shop
    Last Post: 08-03-2008, 08:58 PM
  5. Low calcium levels, plasticizers in vinyl liners, leaching cobalt from fibergalss?
    By waterbear in forum Dealing with Alkalinity and Calcium
    Last Post: 04-21-2006, 09:07 PM
