Results 1 to 10 of 58
Thread: Getting Calcium Levels Right
    Aug 2014
    Chelsea AL
    Default Re: Getting Calcium Levels Right
    I'm probably totally confused as to how Ph relates to the amount of acid in the pool. I want more than normal amounts of acid. Is that lower Ph? I thought it was higher Ph. :-(
    Virginia
    The lower the pH, the more acidic the water becomes. The higher the pH, the more alkaline it becomes. pH of 7 is neutral.
    https://simple.m.wikipedia.org/wiki/PH
    Jul 2013
    Northern Illinois
    Great posts, JimK!!!! jmarcum, don't go lower than 7.2.
    Virginia
    Quote Originally Posted by FormerBromineUser View Post
    +1!
    Jul 2013
    Northern Illinois
    So, jmarcum, did you lower that pH? Don't feel bad. We all have been there!
    Aug 2014
    Chelsea AL
    I lowered the ph....now it takes 6 drops of R-0006 to get up to 7.0.
    TA: 40
    CH:250
    CYA:35-40
    Virginia
    Up to 7???
    I hope you didn't drop your pH below 7 (7.2 is the lowest I would go). Doing so risks damage to your pool.
  1. Calcium Hardness Levels for Heater
    By bottomcat in forum Pool Equipment & Operations
    Last Post: 06-01-2015, 08:25 AM
  2. Cloudy water in pool with high calcium levels
    By elocicero in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-09-2013, 12:39 AM
  3. Pool Calcium levels
    By beachfrontpool in forum Dealing with Alkalinity and Calcium
    Last Post: 08-22-2012, 12:39 PM
  4. Higher Calcium Levels & Stable pH
    By chem geek in forum The China Shop
    Last Post: 08-03-2008, 08:58 PM
  5. Low calcium levels, plasticizers in vinyl liners, leaching cobalt from fibergalss?
    By waterbear in forum Dealing with Alkalinity and Calcium
    Last Post: 04-21-2006, 09:07 PM
