Re: Getting Calcium Levels Right
Well, I would try the pressure relief valve for sure. I always turn mine on after I get any air into the system, usually after I clean the pump basket.
The O-ring is inbetween the pump basket and its clear cover. As they start to get old, some pool lube (not vasoline), helps. Eventually they need to be replaced so that you can get a good seal.
