Thread: Stuck Back Wash Valve
    Scottsdale, Arizona
    Default Stuck Back Wash Valve
    My Backwash valve has been getting harder and harder to pull up (It's the kind you twist to unlock and then pull up to select backwash mode) so i bought some new o rings and want to replace and lube them. Well, I can't get the valve to come out. It will pull up to the same point as the backwash selection but not any further with all the screws removed.
    I tried a little dawn dish soap but that did not help at all.
    Any advise?
    Scottsdale, Arizona
    Default Re: Stuck Back Wash Valve
    I just realized i posted this in the wrong section... I got it fixed though. I used Pam Cooking Spray and it slid out pretty easy. Lower o ring was destroyed. All good now.
    Jul 2013
    Northern Illinois
    Great!!!
    Anonymous [GDPR] European in the UK Guest
    The best time of year for fixing stuff!
    Happy new year to all.
    Jul 2013
    Northern Illinois
    Happy New Year!
  1. PH after Acid wash
    By markphin in forum Pool Chemicals & Pool Water Problems
    Last Post: 10-23-2014, 01:52 AM
  2. Would you Acid Wash
    By topcorner in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2011, 04:29 PM
  3. Back wash to waste
    By rollinrock in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 08:16 AM
  4. Acid Wash
    By txhomebrew in forum In-Ground Pool Construction and Repair
    Last Post: 03-19-2009, 11:52 AM
  5. Back-wash hose busted.
    By Pool_Mike in forum In-Ground Pool Construction and Repair
    Last Post: 05-21-2007, 12:36 PM
