Hello all, I'm new on here. I have a problem with my empty cement pool. It's about 30 years old. 33,000 gallon cement floor with a fiberglass side liner about 3 feet high that runs all around the pool. I had a 4 inch a day water leak. Found out the leak was between the fiberglass liner and the floor. I bought some Wett 700 epoxy. Drained the pool, removed the old hydro static plug and sealed the leak around the liner. Then I noticed there was water seeping through the concrete at the deep end around the hydro static plug. It's a bare concrete area about 2 feet diameter. Not a bad leak it just seeping through the concrete. So I figured it water can leak up it can leak out when the pool is filled. So I might have another leak area to fix. My question is what is the best way to seal this? I was thinking some compression concrete or maybe my epoxy. I'm also going to paint the pool while it's empty. First I need to get this seeping situation fix. Thanks in advance for any advice. Sean
