Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Can I use household bleach for chlorine?
FAQ
register
Results 1 to 8 of 8
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
06-14-2006
12:15 PM
#1
dianam
View Profile
View Forum Posts
--General User--
Is household bleach the same as the chlorine from the pool store?
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Max Chlorine PPM for Fiberglass Pools
CYA added per 3" tablet of trichlor - the answer?
Chlorine tabs vs chlorine bleach generic
By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
6
Last Post:
06-13-2013,
10:28 AM
6% household bleach equivalent to lithium hypochoride granular?
By magnus in forum Using Chlorine and Chlorinating Chemicals
1
Last Post:
05-24-2013,
10:51 AM
Household Chemical for hardness
By arobinstk in forum Dealing with Alkalinity and Calcium
5
Last Post:
05-25-2012,
01:11 AM
Household bleach to shock?
By Rsnyder in forum Using Chlorine and Chlorinating Chemicals
4
Last Post:
07-16-2006,
02:51 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
