Results 1 to 10 of 20
Thread: Question about CH Test Coloration
    Aug 2014
    Chelsea AL
    Default Question about CH Test Coloration
    When using my Taylor test kit to test my CH the instructions say if CH is present the water will turn red. My water does not turn "red" it turns a VERY light pink. Performing the next step of the test where the water should turn blue it turns a purplish color then a VERY light blue. It's almost hard to tell there's any color in the water be it red or blue. Is this normal?
    I this test and the CYA test to be the most subjective of all the tests. The black dot "disappearing" is not cut and dry by any means. If I try really hard to make out the dot and I can does that mean the test is not complete? Should I literally not even know there's a dot there?
    Default Re: Question about CH Test Coloration
    Good questions.
    I think pink means you don't have a lot of calcium. And I've noticed it turns more purple than blue. Maybe old reagents?
    The CYA test takes practice. You should face into the sun with the vial at your waist level. The GOOD thing about the test is you can keep repeating it without using more chems. Just pour the solution from the black-dot vial back into the squeeze bottle and try again. Do it as many times as you need till you get a feel for it! I ALWAYS do it at least twice, sometimes 3x. It only takes another minute.
    Another thing is always try to do the test EXACTLY the same way each time, especially when you do it on a different day. You'll figure it out with practise.
    Aug 2014
    Chelsea AL
    Very helpful. Thank you!!! I never even though about pouring the water back and forth.
    So I guess it is supposed to turn literally red? I have a huge thing of calcium up. I bought it when I started the pool up for the first time last year and I've only ever used 1 scoop of it. My pool has really bad scaling and I read that can be caused by low calcium because calcium is pulled from the plaster. So should I add some? If so how much?
    Another quick question... My PH was low so according to the pool calculator, which BTW I like so much that I bought the app today, so I added the suggestion amount of Borax. How long should I wait to retest ph? I ask because I went ahead and retested after about 2 hours and now the Ph is off the chart high. I'm hoping that is because I am just too impatient. :-)
    Scaling from LOW calcium?????
    Usually it is from too high calcium and too high T/A
    Aug 2014
    Chelsea AL
    That was something I read. I'm definitely not saying it's accurate. The way they explained it was calcium would be pulled from the plaster if the level in the pool was too low. I take it from you reply though that it likely not true. :-)
    Pulling calcium from the walls is true if calcium is too low. But scaling is from too high calcium.
