Thread: Accidental over filled pool
    sabres07 is offline Registered+ Thread Analyst sabres07 0
    May 2012
    Buffalo, NY
    Default Accidental over filled pool
    I accidentally left my garden hose on while adding water to my in-groud pool....for 30 hrs!!! However, the water did not overflow the top, it appears as though the water seeped down between the liner and wall of the pool....and then seeped into the ground surrounding the pool. What are the ramifications of such an act? My liner appears in tact with no wrinkling. The base of the liner seems stable from the inside of the pool. No air or water bubbles behind the liner. Did I get lucky here???
    16'x32' oval 15K gal IG vinyl pool; liquid chlorine; Hayward cartridge filter; Hayward 3/4 hp pump; 3/5/2012hrs; Taylor 2006c; utility water; summer: none; winter: vinyl / water bags; ; PF:8
    Jul 2013
    Northern Illinois
    Default Re: Accidental over filled pool
    Sounds like you were lucky, but how do you know there is water behind the liner if you have no wrinkles?
    He doesn't know. He said there are no bubbles of air or bubbles of water. There could still be water behind the liner, of course. I don't think there's anything you can do except hope the water doesn't cause the wall to rust.
    May 2012
    Buffalo, NY
    There is no evidence of any problems so far. The liner looks the exact same as before, and there doesnt seem to be any softness under the liner/ floor area....hope I didnt erode anything under the pool.
  1. Pool filled in!?!?
    By sheawoods in forum --cleanup--
    Last Post: 07-12-2015, 04:48 PM
  2. Pool is filled, now what do I do?
    By CrazyKittyLady in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-24-2013, 11:20 PM
  3. Just filled the pool
    By RazberryT in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-06-2007, 11:21 PM
  4. Just Filled New Pool
    By Simmons99 in forum In-Ground Pool Construction and Repair
    Last Post: 08-23-2006, 11:06 AM
  5. Just Filled Pool Please help with BBB.
    By grdnchik in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-19-2006, 10:05 PM
