mas985
The study seems pretty clear to me which states that they SAW no observable difference in water quality after 2 hours. If the debris sinks, then a vacuum can easily remove it without "stirring it up". The only time I have heard of someone having an issue like you are describing is when they just killed a bunch of algae and it sunk to the bottom. That debris is very light weight and can be stirred up easily but when cleaning up algae after it is killed, you should be running 24x7 anyway.
Yes but the human eye can't see very much, if anything smaller than 30 microns. You cant see electricity so is that safe then? Although thankfully rare chlorine resistant strains of bacteria do happen so filtering them out is necessary and if you filter at that level very little chlorine or chlorine reactions are needed to keep the pool in top condition. If what I wrote was more expensive than normal I could understand the objection but I achieve these results on a lot less, call it a bonus.
Why only a minute? Chlorine does not stop killing after one minute, it should continue killing these things if the level is set properly.
Now that is a miss understanding, chlorine doesn't stop killing of course but it can terminate most common bacteria and virus etc in under a minute. That's why when the level of chlorine present is sufficient then high filtration rates are not needed as the report also showed. In fact because most people have pumps to big for there filters they are wasting more electricity breaking up whats filtered into smaller parts that just pass through the filter.
So what? Again, there is no good reason to filter the water at any specific turnover rate. It just doesn't matter to sanitation. Aesthetics, perhaps but only to some.
Yes agreed, I just made observations about the rate Not a recommendation.
Removing floating debris and debris that has sunk to the bottom of the pool is entirely up to you. It is only based on your personal preference.
Some people like me could care less if there is a little debris in the bottom of the pool or even on the surface. My priority is to minimize run time.
My priority is to minimise electricity bills, and cleaning all the other parts come as a bonus. My pool is let to paying guests they can be quite anal.
Other people are quite anal about a pristine pool and thus require lots of run time so every spec of dirt and debris are immediately removed from the pool. However, this desire sometimes comes at a large cost.
