Results 1 to 1 of 1
Thread: Old impeller has screw thru hole, new motor doesn't have internal screw hole thread?
    Jul 2014
    Madison, WI
    Default Old impeller has screw thru hole, new motor doesn't have internal screw hole thread?
    New motor is on the left, old motor on the right. Impeller is in the middle, with its screw thru hole. Do I need to do anything special with the impeller since there's no way to screw it down into the CCW threads in the motor shaft?
    Attachments Pending Approval
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31.25% muriatic acid.
  1. Dimensions of impeller locking screw
    By djKoch55 in forum Pool Equipment & Operations
    Last Post: 05-24-2014, 05:23 PM
  2. Did I screw up my liner?
    By proximo in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2013, 06:23 PM
  3. My Screw UP = Foamy Mess
    By lm8838 in forum Dealing with Algae & Slime
    Last Post: 06-07-2008, 04:54 PM
  4. Should rain screw up my numbers this much?
    By fishandfly in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-11-2008, 03:27 PM
  5. Did I screw up big time? Bromine by mistake.
    By LennPrice in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-08-2006, 09:11 AM
