Results 1 to 10 of 48
Thread: Replacing a motor on a pump, and getting the correct size for your pool?
    Jul 2014
    Madison, WI
    Default Re: Replacing a motor on a pump, and getting the correct size for your pool?
    I borrowed an ammeter today, and measured a draw of 19A on high and 4-5 on low, on each leg. I don't know much about motors, but that seems excessive. I could see a startup draw spiking really high like that, but not a sustained draw 3x higher than the motor rating.
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
    mas985's Avatar
    Pleasanton, CA
    Yes that is excessive and likely due to interference somewhere in the wet end. If the pump was run without water flowing through it for too long, the water can heat up and deform the wet end causing an interference issue with the impeller. But usually you will hear that when running the pump.
    Mark
    Jul 2014
    Madison, WI
    I did just take everything apart to get things ready for a warranty replacement motor to arrive tomorrow. I did notice the above, that this seal was slightly crooked. Could this cause a major problem?
    I never noticed any odd sound until just after I hooked up the pump to some plumbing I re-did (took out two shutoff a and replaced them with a pair of 3-way valves.) Everything seemed fine until a few minutes after running the pump. It was struggling to reach full prime, and it might have been because the water level was too low (pulled all the water out of the skimmer), so I shut it off and filled the pool up a few extra inches over the course of 3 hours. Turned it back on later that night and it sounded really funny, with a sort of him to it like it was seizing up.
    FWIW, the pump had run fine for a full week up until I decided to change up the plumbing in an attempt to convert a vac line to an either/or line (vac or return.) There may have been a problem in the height of the new plumbing to the first valve, which was about 8-10" above the pump intake port.
    mas985's Avatar
    Pleasanton, CA
    I think you may have the seal in backwards. The ceramic end (white) goes into the motor mounting plate with the ceramic facing towards the impeller. The carbon side (black) faces the ceramic on the impeller side.
    And yes, the surfaces must be perfectly parallel and flush or it will ruin the seal and cause friction issues.
    Mark
    Jul 2014
    Madison, WI
    This is exactly how it was on the original seal with the pump, from the factory. I just put a new seal in when I got the 1st replacement motor.
    I think my wet end has it configured backwards, with the seal part with the spring mounted into the motor mounting plate.
    Jul 2014
    Madison, WI
    Here's the motor mounting plate. The portion of the seal with the spring is installed here, and the ceramic (white) side faces this half of the seal.
    mas985's Avatar
    Pleasanton, CA
    That is backwards. The spring side goes on the impeller side and the white ceramic goes in the mounting plate. That is what is probably overloading the motor. But you probably have ruined the seal so I would replace it.
    Mark
  1. Replacing a Dead Pump Motor
    By Peabody in forum Pool Equipment & Operations
    Last Post: 06-07-2012, 12:46 AM
  2. Replacing pump motor
    By bbsmith in forum Pool Equipment & Operations
    Last Post: 04-27-2012, 11:51 AM
  3. Correct Pump Size for Filter
    By RobDHW in forum Pool Equipment & Operations
    Last Post: 05-18-2011, 11:27 AM
  4. Need advice for correct size AG pump/filter!
    By seadogg in forum Above-Ground Pool Construction & Repair
    Last Post: 05-24-2008, 03:38 AM
  5. Replacing Pump Motor Only
    By let_her_flicker in forum Pool Equipment & Operations
    Last Post: 06-06-2007, 10:43 AM
