Thread: Crack in multi port valve
    Oct 2011
    Southeast
    Unhappy Crack in multi port valve
    I just found a small crack right where the water intake pipe goes into the valve. I figure I will have to get a new one but until then I have put a circular metal clamp over it, is this ok to do??
    16X32 Inground 23,000 gal vinyl lined Hayward S200 High Rate Sand Filter Hayward Super Pump 1HP 20GPM 8.25% Bleach for chlorinating.
    Howell NJ
    Default Re: Crack in multi port valve
    You should be fine smoovie... As long as its not leaking... But even if it was leaking you can probably stop a severe leak with putting a clamp and piece of rubber of some sort around the crack..
    Hope this helps..
    Of course a new valve is in order...
    12x18 vinyl AG 6.2K gal; Hayward equp: 16" sand filter (spring clean up) -- Xtream 100 sft cart (after clean up) -- Power Flo Matrix 1hp 2spd pump w/ AO Smith motor
    You could try some pool epoxy and then the clamp. It will probably still leak but should slow it down significantly. Replacement is best.
  1. Pentair multi port valve 27-1141 - DE enters the pool
    By wsommariva in forum Pool Equipment & Operations
    Last Post: 05-22-2015, 11:09 PM
  2. clicking / pebble sound in multi port valve
    By lskul60 in forum Pool Equipment & Operations
    Last Post: 08-22-2012, 12:09 PM
  3. Hayward Multi Port Valve for Sand Filtration
    By rondun in forum Pool Equipment & Operations
    Last Post: 05-22-2012, 10:55 PM
  4. Multi Port Valve Gasket
    By CyberGypsE in forum Pool Equipment & Operations
    Last Post: 09-06-2006, 09:33 PM
  5. Adding a multi port valve?
    By KirstenHW in forum Pool Equipment & Operations
    Last Post: 06-02-2006, 04:50 PM
