Thread: Hi ~ Newbie trying to learn - Not sure what to do to fix my test #s
    May 2015
    Canada
    Default Re: Hi ~ Newbie trying to learn - Not sure what to do to fix my test #s
    Hi Carl - Thanks so much for helping me! Yes, the CC is 0
    I was raising the FC because I thought I should shock the pool first before we start using it. Ben's Best Guess chart shows min levels of FC of 10-15 for lower CYA (which I am assuming mine is) for shock levels. Maybe I don't need to do this as the water is nice and clear already?
    I just came back with the Muriatic Acid, so I will use that tonight when the wind dies down a bit to bring the PH levels down. I'll also try the Tri-Chlor tabs if I can find them after I'm back next week if they are still needed.
    I added the salt (360 lbs) according to the recommendation in the Intex manual yesterday, and I haven't actually measured the salt level. I ordered the k-1766 kit from Taylor but it hasn't arrived yet. The pump itself has an indicator for low salt, which isn't flashing - but that's all I know at the moment.
    Should I get a salt test strip in the meantime?
    Thanks again!
    Intex Ultra AGP rectangular 32'x16'x52" (15000 US Gallons), Intex SWCG .95 HP Pump, Titan Titanium HP 80,000 BTU, Taylor k-2006 kit
    Usually the salt test function on an SWCG is best, but Intex, being a low cost system may not be as reliable. I just don't know.
    With your numbers and a clear pool why would you shock? No need I can see.
    May 2015
    Canada
    Thank you!
  1. Newbie with first-time test results
    By halefmly in forum DPD-FAS based testing
    Last Post: 07-28-2006, 10:16 PM
  2. Newbie first test results. Some questions?
    By mjs31 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-02-2006, 04:37 PM
  3. First test from a pool newbie
    By JPAub in forum DPD-FAS based testing
    Last Post: 06-20-2006, 11:47 AM
  4. Newbie in Louisiana Test Results. Help!
    By rfreeman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-17-2006, 10:25 AM
