Here are my test results. I know that my Cl is low...I plan to shock in a few minutes.
TC 2
Alk 70
CYA 25-30
pH 7.5
26k gallon above ground pool
Sand filter is running 24/7. I am on a cistern, so I can't drain the pool or do much vacuuming to waste. For those unfamiliar with a cistern, it is a storage tank and I catch rain water for my water supply...so I can't just let the hose run wild.
Do I need to boost my CYA? My pool is a blue cloudy pool. No visible algae. What Cl level should I go to? 15, 20?
Thanks for the help.
