Thread: Pool Cover Mess W/ Chemistry...???
    Swansboro, NC, USA.
    Question Pool Cover Mess W/ Chemistry...???
    My pool went from green to crystal clear all thanks to you great people on this forum!!!! THANK YOU ALL SO MUCH!
    Okay, now for my question...
    We've had alot of rain over the last 24 hours and getting ready to get all the rain from TS Alberto. I have an Intex Easy Set 18' pool and the cover that goes with it. Would it bother the chemistry of the water at all by covering the pool during the day when I know its going to rain or at night?? I keep thinking I'll take the cover off and have algea BUT I will check the water everyday like normal and add my bleach to it as normal. Just in the past 24 hours from all the rain the pool is getting cloudy. I dumped in bleach last night and its looking better this morning but I do not want a green pool again Should I put the cover on there just to keep the rain water and debris out? Is this helpful? Any suggestions?
    Thanks again!!!
    Default Re: Pool Cover Mess W/ Chemistry...???
    I think I would put the cover on just to keep the debris out, IF you don't have strong winds that would rip the cover. If the winds are too high, forget the cover and just deal with the water when the storm is over. If it were my pool, I'd go ahead and shock it now, and keep it at shock level as much as you can throughout the storm so that nothing gets a foothold and starts growing in there, especially if you lose power for an extended period of time.
    Good luck, hope you don't get any damage.....
    Swansboro, NC, USA.
    Smile Re: Pool Cover Mess W/ Chemistry...???
    Thanks Janet!!! I bought a big ball today to put under the cover and hope that'll help keep from a puddle forming on the cover.
    This shouldn't make anything "grow" under there??? I'll take it off everyday just to make sure the water is staying clear and test everyday. I'd like to put the cover on everytime it rains because it turns it cloudy so fast.
    Thanks again!
    duraleigh Guest
    Hi, Quenn,
    Reread Janet's post suggesting you shock.
    Something other than rainwater is making your pool cloudy.
    Shocking just may head off what you're trying to avoid.
    Swansboro, NC, USA.
    Thanks! I started bringing it upto schock levels tonight.
  1. Pool help, cloudy mess, no experience.
    By daddyjmo in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-12-2011, 03:39 PM
  2. With your help.. we are going from mess to success!
    By senniss in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-10-2010, 10:27 AM
  3. What a mess in my pool
    By Pool_Mike in forum Pool Equipment & Operations
    Last Post: 09-25-2006, 11:11 AM
  4. Don't want to mess up the pool
    By doriec in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 01:15 AM
  5. help...have I got a mess
    By tazt60968 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2006, 11:07 AM
