Results 1 to 10 of 14
Thread: Oops. Now what? Cloudy water, high numbers.
    Jun 2014
    NC
    Unhappy Oops. Now what? Cloudy water, high numbers.
    We opened a few weeks back to crystal clear water with a small clump of likely vacuumable stuff at the bottom center.
    Dunno why, but I guess I forgot everything I learned here last season.
    I did not test the water. I *ass*umed everything would be 0.
    I added ½ lb of shock: 53.5% Trichloro-s-triazinetrione 46.5% cereal filler [48.6% Available Chlorine]
    Within hours, the water turned medium green and so cloudy you couldn't see the bottom.
    Several [10?] gallons of 8.5% bleach later, the green is completely gone, but the cloudiness remains.
    The filter has, for the most part, run 24-7 with constant cartridge changes. There's no green on the cartridges any longer.
    Today's numbers:
    >34 FC. I stopped when I hit 120 drops as the sample had not turned clear. Didn't know if I should continue.
    7.3 pH
    >780 TA Again, I stopped @ 78 drops. The sample turned from the green to yellow, but never turned red.
    78 CYA
    What next?
    5.5k gal 18'x48" Intex Easy Set AGP. PF=18
    Jun 2014
    NC
    Default Re: Oops. Now what? Cloudy water, high numbers.
    No suggestions, hints, incantations?
    Jul 2013
    Northern Illinois
    Sorry about that. Would you please update with your current numbers (including CC)?
    Another question, have you ever tested your fill water?
    Jun 2014
    NC
    We had to get the water tested at our local pool store as we're about out of our Taylor reagent.
    Their numbers:
    >16.69 FC
    0 CC
    6.9 pH
    13 Hardness
    32 Alkalinity
    42 CA
    .2 Copper
    .1 Iron
    We've never tested our fill water. We use our neighbor's city supply as we didn't want to use our well water.
    The water is still cloudy white.
    We change the stock filters about every 8 - 10 hours.
    The pump has been running pretty much 24/7 for close about 7-10 days.
    Jul 2013
    Northern Illinois
    Your last readings and the pool store's readings are too different. I hope you didn't buy anything from them except reagents!
    I would wait on your chemistry until you get new reagents except for keeping FC in the pool.
    If you haven't ordered reagents yet, I use Amato Industries on Ben's Amazon link. Don't be afraid of shipping costs with them. It looks like each item you add to the cart has high shipping, but when you check-out, it all gets discounted. They fill orders quickly.
    Jun 2014
    NC
    Can you provide the Amato Industries on Ben's Amazon link?
    I can't seem to locate it.
  1. First Time Pool Owner Battling with Cloudy Water, High CC, High Ammonia!
    By yekalri in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-14-2013, 07:48 PM
  2. Testimonial to POP...numbers better everyday but still need help with cloudy water
    By poolprobe in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-26-2012, 10:54 PM
  3. oops I caused a perfectly clear pool to be cloudy
    By Cords in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-06-2011, 10:08 AM
  4. Pool Water Cloudy - All Numbers are Good?
    By wetshoes1 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-29-2007, 07:00 PM
  5. Cloudy water - here are my numbers
    By ksturge in forum DPD-FAS based testing
    Last Post: 07-07-2006, 02:59 PM
