Thread: solar cover 'fish"
    Unhappy Re: solar cover 'fish"
    you guys down south are lucky...I'm in New England. I opened my pool on Memorial Day weekend and did the spring opening routine and topped off the water level. the water temp was 54 degrees then and now about 64 on a hot day. Seems to lose about 5 degrees overnight depending on the nighttime temps. If we have a heat wave (about 5 days of 90+ weather) the water temp might get up to 75 or so if I use the solar cover. I'm thinking of a solar heater but then I'd need to use the cover very night, then I'd need the reel...nothing but money...thanks for your replies
    Default Re: solar cover 'fish"
    Come on, bite the bullet and get a solar heater and use your blanket. What's worse, a few minutes day and night to put the cover on/off OR not getting use out of an expensive pool because its too cold? We live in probably the coldest part of the country by far (often called the Nation's Icebox) and we enjoy pool water in the 80s and higher most of the summer. As for $ options on a reel, I have two words - DIY and EBay
    Just the first 5 hours of the panels this year our water temp raised 4 degrees, then we were on and offline due to old connections/hoses leaking - we always pay for laziness at pool closing when we open the next year! Our pool was 78 degrees this morning, sun is shining as we speak so I expect low to mid 80s water when I get home. Where is my pool floatie???
  1. Safety Cover "Mate" Cover? Are they worth it???
    By Pipecrew in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-05-2011, 04:30 PM
  2. "drying" a solar cover
    By denanbob in forum Above-Ground Pool Construction & Repair
    Last Post: 09-26-2006, 08:44 AM
  3. Pool safety cover. "The Hugger Cover"?
    By chrisinaz in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 10:32 AM
  4. A plus for solar fish
    By salinda in forum Pool Equipment & Operations
    Last Post: 05-16-2006, 01:59 PM
  5. Solar Fish??
    By rmeden in forum Pool Equipment & Operations
    Last Post: 05-08-2006, 07:52 PM
