Re: need help w/ my pool.
You can wait until Fall and drain some water off, which would dilute the amount of Baquacil, which may speed the process up a day or so. However, for the amount of $$$ you will save, and the CLARITY of your water, I would suggest changing now. Look at around the last page of this thread and look at my pictures of my conversion. Look at the last couple after the conversion. I can see my bottom drain plain as day now, almost like looking through glass. On Baquacil, when it wasn't scattered-smothered-covered in algae, then the water had the hazy, milky look you mentioned. It's your pool and ultimately your decision. I'm just giving my unbiased opinion as someone that's been there/done that, and I would say switch now. You will have the cleanest, clearest pool for a great 4th of July party! Plus, the $$$ you save from chemicals will buy some nice healthy t-bones for the grill.
Unless you have a surplus of Baquacil chemicals hanging around, aren't you going to have to spend more money to buy more of them if you wait until the end of the season? From the others than have converted, you should be able to do it in a week or less. If your water seems OK at the moment, you could wait until the next dosing of chemicals is needed and start the conversion then. Read through the other posts for instructions but the first step will be buy lots of bleach. Find a post by mwsmith2 and download his Bleach-calc program - you can use that to figure out how much bleach you will need for each initial dose. Good luck.
Peter
If you did not add anymore Baquacil to your pool, it should be real easy to kill off the remaining chemicals with bleach. You can convert now. You must have had a lot in your pool, because most people will have 0 when then open their pools after winter.
Yes, You can convert
Even if you wait to next year, you don't have to drain. Where I live I lose about 1/3 of my water due to evaporation. Yes, water evaporates under the cover. Read up on converting at the Baquacil thread.
Again, if you did not add the stuff to your pool, you can convert. You can convert even with high levels, but it will take a lot of bleach to kill the Baquacil off. It can be done and lots have done it.
After you convert, you will probably want to change out your sand as it will be gunked up with Baquacil.
Good Luck
