Results 1 to 10 of 27
Thread: Solar Panel plumbing and flow rate
    mas985's Avatar
    Pleasanton, CA
    Default Re: Solar Panel plumbing and flow rate
    Maybe a picture of your equipment would help me understand the layout a little better.
    Mark
    Apr 2014
    Slatington, PA
    I cant simply upload photos, as the link is asking me for a URL address?
    18' x 33' AG pool, 2HP US Motors / PMX pump with 200 # Columbia Sand Filter, (2) 4 x 20 FAFCO Solar Panels
    Jul 2013
    Northern Illinois
    Upload your pics to photobucket, flicker, or some other site first. That will give you an url
    Apr 2014
    Slatington, PA
    Mas985,
    Attached are photos of my valve manifold and the solar panels.
    Apr 2014
    Slatington, PA
    Not sure if the link worked so here it is again. http://s725.photobucket.com/user/slachey/library/
    mas985's Avatar
    Pleasanton, CA
    In this picture, are the panels on the left and the equipment on the right? Because the valve position would not be correct position for solar operation. You want to close off the bypass (partially or fully with handle upward). Otherwise, no water will flow through the panels.
    Mark
    Apr 2014
    Slatington, PA
    The panels are to the left and I have reconfigured the valve so the "off" position is vertical when all flow is going to the panels.
  1. Figuring Flow Rate
    By bottomcat in forum Pool Equipment & Operations
    Last Post: 07-04-2014, 03:48 PM
  2. Flow rate sensor?
    By henryb in forum Pool Electronics
    Last Post: 08-31-2013, 03:51 PM
  3. Solar panel plumbing mystery
    By stavpeter in forum Pool Equipment & Operations
    Last Post: 11-20-2012, 02:58 PM
  4. Sungrabber solar panel flow rate calculation
    By TRHOD12 in forum Pool Equipment & Operations
    Last Post: 05-19-2010, 01:39 AM
  5. Design flow rate vs maximum flow rate...
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 07:50 AM
