Thread: Remington Solar Chlorine-Free “Sun Shock”
    May 2011
    Reading, PA
    Default Remington Solar Chlorine-Free “Sun Shock”
    Anybody ever use the Remington Solar Chlorine-Free “Sun Shock”? What has been your experience with it? I will be away a lot this summer and with the BBB method I must put bleach in every 2-3 days. I was thinking this would extend or replace the need to put bleach in so often.
    Thx!!
    Paige
    In ground, outdoor, vinyl liner, 22,000 gallons w/Aqua Genie skimmer installed in 2008, 1 HP Hayward 2-speed Super Pump and Hayward pro series high rate S244T both installed 2016
    Virginia
    Default Re: Remington Solar Chlorine-Free “Sun Shock”
    I took a quick look and it seems it adds copper to the water to help prevent algae growth.
    Personally, I wouldn't use it. Copper can stain your pool and turn hair green. Also, while it does help prevent algae, it is not a good sanitizer.
    If you can't find someone to add bleach for you, perhaps you could add enough before you leave to last until you get back (how long will you be gone at one time?).
    If you want to add an algaecide for extra protection, the only one recommended here is a 60% polyquat such as this;
    http://www.amazon.com/Kem-Tek-KTK-50.../dp/B0030BEI0Y
    May 2011
    Reading, PA
    Thumbs up Re: Remington Solar Chlorine-Free “Sun Shock”
    Thx!
    Jul 2013
    Northern Illinois
    You can also buy a cheap floating puck dispenser and some pucks for the short term.
    You said you would be away a lot, though, so it would be better to train a friend in basic FC/CC/pH testing and dosing. It would make a nice exchange for getting to use the pool while you're gone.
  1. Need help with my Free Chlorine
    By videotonyk in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-23-2013, 09:45 AM
  2. Aqua Silk™ Chlorine-Free Shock Oxidizer
    By Lawrosa in forum Pool Chemicals & Pool Water Problems
    Last Post: 01-04-2013, 12:16 PM
  3. Solar blanket on a free form pool.
    By ohpoolboy in forum Pool Equipment & Operations
    Last Post: 04-04-2008, 05:37 PM
  4. free chlorine?
    By DONNIE in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 12-23-2006, 01:42 AM
  5. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
