Results 1 to 10 of 11
Thread: Chlorine level - too low - but why???
    Default Chlorine level - too low - but why???
    FAC = 0
    TAC = 0
    CALC. HARDNESS 220
    CYA = 30 (SO I ADDED CHEM TO RAISE IT ABOVE 30)
    TOTAL ALK = 120
    pH = 7.8
    COPPER, IRON = 0
    PHOSPHATES = 0
    Why can't I maintain chlorine?? This never happens to me.
    I use leslie's trichlor hockey pucks in an inline feeder - just like I’ve done for years and years. Pool is covered and heated. Only trace amounts of green algae. Taylor OT test kit reagents only a year old. Will use my powdered shock only as a last resort due to my commitment to make my new liner stay unbleached and supple. My area is northeast.
    I/g vinyl; 28k gal.; 1.5 hp de filt
    Jul 2013
    Northern Illinois
    Default Re: Chlorine level - too low - but why???
    Pucks will not add chlorine as fast as you need it. I would recommend only using liquid chlorine (bleach, liquid pool shock) for your sanitizer except when going on vacation. Pucks will just raise your CYA even higher. The results of that will be that it will be even harder to maintain chlorine in your pool.
    Go get bleach or liquid chlorine (either from WalMart or Menard's/Home Depot, etc). Add about a half gallon a day. Report your results and let's go from there.
    Trace amounts of algae are too much. I recommend getting a better test kit (Taylor K-2006C). Worth every penny and I promise it will pay for itself over the season.
    I have a relatively new vinyl liner and understand your concern. If you follow the forum's advise, your water will be sparkly clear and your liner will be just fine!
    Added half a gallon of Clorox GERMICIDAL bleach. Home Depot carried that, plus 'outdoor' variety for decks. So far, so good. thanks!
    Jul 2013
    Northern Illinois
    Great! How much did you pay for that? It can be expensive!
    $4.39. Isn't this this part of the cheap, but effective BBB method?
    Jul 2013
    Northern Illinois
    Well, it's a great product, but $4.39/gallon is tough. Many people just use plain, unscented 8.25% laundry bleach. I use pool shock which is the same stuff but at 12.5%. I try not to pay more than $3.00/gallon and sometimes I get it for $1.99/gallon at Menard's on sale. If you're handy at math you can figure out what is the better deal for you. If germicidal was cheaper, more people would use it!
    wow
    that IS a big price difference
    Jul 2013
    Northern Illinois
    The germicidal bleach is supposed to have extra things in it for E. coli and some other bacterias. You're the first person I know that has used it, though. I have read that it is a great product -just expensive.
    The main thing with bleach is to make sure it's plain, unscented, not the splashless kind, and that the percent chlorine is listed in the ingredients. With both bleach and "pool shock", the main thing is to also look at the date code so you know it's fresh. The code will be something like 15169. This means it was bottled on the 169th day of 2015. Chlorine loses strength over time so this is very important. Also, don't buy anything sitting outside in the sun as sun and heat increases the rate of break-down.
    May 2013
    Concord,ca
    That 169 deal being 169th day of 2015 is great info. I have never heard it before. THANK YOU
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Jul 2013
    Northern Illinois
    Dansdad: You're welcome!
    Francis: How is the pool doing?
  1. Unable to keep chlorine level and CYA level has dropped from 38 to 21 in 1 day.
    By lizbyrne2000 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2013, 12:41 PM
  2. CYA level and chlorine level and pool store recomendation
    By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 11:25 AM
  3. Chlorine level
    By Jeffski in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-23-2007, 10:32 AM
  4. Keep your chlorine level at 15
    By sisie5 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-21-2006, 04:02 PM
  5. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
