Results 1 to 1 of 1
Thread: Surface skimmer frame set pool bracket mod
    May 2011
    Lake Mills, WI
    Lightbulb Surface skimmer frame set pool bracket mod
    After my skimmer bracket cracked I saw this tip on Amazon. You fill the bracket sides with Bondo for extra strength. The $6 Bondo is cheaper than buying $20 brackets, and will help you avoid skimmer downtime. I fixed the crack with epoxy, then did the bondo. It is stronger than ever!
    -8200 gallon 20' x 4' (3.5' really) Intex Ultra Frame. Well water w/high alkalinity.
    -"A" filter cartridge, surface skimmer. I spray the A filter every 2 days when I check the chlorine. I only use bleach (3-6), muriatic acid (to knock down ph & alkalinity), and stabilizer (cya 50).
  1. Skimmer not catching debris floating on surface
    By WillB in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-04-2014, 06:37 PM
  2. Wanting to change wall mounted screen filter to a skimmer on Intex Ultra Frame pool.
    By The Brabarian in forum Intex-type Pool Setup & Operations
    Last Post: 05-04-2014, 11:51 AM
  3. Fiberstars 6008 Pool Light Hot Mirror bracket assemby
    By CMill10 in forum Pool Electronics
    Last Post: 06-28-2012, 07:29 PM
  4. pool step bracket
    By mike_311 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2012, 12:24 PM
  5. Oil slick looking surface inside skimmer
    By mneal in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-28-2006, 12:02 PM
