Results 1 to 10 of 12
Thread: Probably Need a New Pump
    Jul 2013
    Northern Illinois
    Default Re: Probably Need a New Pump
    Also, my sparkly situation may have to do with the fact that (unless there are users in the pool), I keep my auto-cover closed about 22 hrs/day. Skimmers don't work with it closed...
    mas985's Avatar
    Pleasanton, CA
    One more thing to keep in mind is when you run 24/7 you don't give the smaller particles time to settle out so they will tend to remain in suspension and in this case, the only way to remove them is by filtering. It is far more cost effective to turn the pump off for several hours and let these particles settle out so they can be vacuumed up. However, if you don't have an automatic vac, it may not be time effective to do it that way. It all comes down to how you want to manage your pool and the how much you want to pay for it.
    Mark
    leena is offline Registered+ Thread Analyst leena 0
    May 2012
    North GA
    just letting you know that after 24 hrs with the new pump and filter, it drastically improved the clarity of my water. Before I always had to add floc and let the remaining dead algae particles settle then vacuum to waste. Id repeat the letting it settle and vacuum constantly to keep my water clear. I only added floc once a yr. It seemed to stay in the water bc even the small particles would sink to the bottom for several weeks after using the floc.
    However, this time I just wanted to see if the new filter and pump would do anything. So I didn't add the floc. I killed the algae then vacuumed to waste twice. However the water was still very hazy from the tiny dead algae particles that were floating around and wouldn't settle to the bottom. So I hooked up the new filter and pump and after 24 hrs, big difference, after 3 days.. clear water. That was running it on low. Running on low, the heavy stuff still sank to the bottom so I stirred it up but it didn't seem to filter it out bc the water flow was so gentle, it the big stuff just sank back to bottom. So I stirred it up again and ran filter on high for 24 hrs. This did get more of the big stuff out but some still settled to the bottom. My electric co shows electrical use every 24 hrs so I could see that runnin it on high did increase my energy use more.
    SO I think I will run on low for 3 hrs ea day or every other day, vacuum to waste anything that settles to bottom. This is the first time I'd gotten clear water after an algae outbreak without having to add something to make the tiny particles settle to bottom, so I know that a properly sized pump and sand filter does actually filter stuff out. My old setup didn't appear to filter out anything, not even bugs much less small dead algae particles.
    24 round 12-14K gal AG vinyl pool; chlorine tabs and bleach; 300lb Hayward sand filter; Hayward 1 HP 2-speed pump; K-2006
    Jul 2013
    Northern Illinois
    That is a great update. Congrats on the clear water!
    mas985's Avatar
    Pleasanton, CA
    One of the issues with sand filters is that they usually have a hard time filtering out dead algae because it is smaller than 20 microns (filter capability). One way to help the filter is to add a cup or two of DE. This will help remove the dead algae much more effectively.
    Mark
    Jul 2013
    Northern Illinois
    I ALWAYS add DE to my sand filter after backwashing. It is one of the greatest advantages to having a sand filter IMHO. Here's how: (copied from a longer post)
    1) Backwash your filter. Note the pressure it's running with.
    2) mix about 1/3 of a cup of DE into a few gallons of pool water.
    3) pour the mix slowly into your skimmer while the pump is running. If it's a 2-speed, use low speed.
    4) WAIT about 20 minutes and see if the pressure rises. If it does you want it to rise about 1 lb.
    5) If the pressure doesn't rise, or rises less than 1 lb, repeat steps 2), 3) and 4).
    6) If the pressure has risen 1 lb, you are done. (frankly if it goes up 2 lbs, I'm OK with that. ) A 1 lb rise is your target.
    7) If it goes up 5 lbs or more, backwash and start again, but use less DE.
