Thread: Scum line below waterlevel, won't scrub off
    Default Scum line below waterlevel, won't scrub off
    First post but here goes.
    Water test results:
    Cl - 5+ probably closer to 8-9 as I just shocked
    PH - 7.2
    TA - 110
    TH - 280
    CYA - 30 but probably a little less
    I opened a 24' above ground after purchasing this house 1 year ago. Pool has not been opened in 2 years and the cover caved in over the winter. With the help of this forum it took me 2 weeks of dragging out leaves, vacuuming, and shocking with up to 6 bags of CalHypo per day, and 1/2 a bottle of floc to get the water almost perfect and crystal clear.
    But now, I have a scum line that won't scrub off just below the return where the swampy water sat for 2 years. It's a 2 inch wide band almost like a perfect stripe. I've brushed it a couple times and looks better, but now it doesn't seem to want to come off. The rest of the liner looks nice and clean. Please tell me there's a fix to this other than getting a new liner.
    Thanks!
    duraleigh Guest
    Default Re: Scum line below waterlevel, won't scrub off
    Two miracle drugs, Chlorine and Persistence, may very well get that stain off.
    I doubt anything will remove it immediately, but trying a few things and the continued exposure to the Cl in your water will probably minimize it to an aceptable level...maybe even make it go away.
    I have seen several products recommended here on the forum but I have not tried any of them. Others will be along who have.
    PS - Nice work on your water...numbers look good.
    Have you tried the Mr. Clean Magic Eraser by chance? I get the black film on the skimmer box and it takes it almost completely away. Might be worth a try you haven't already...
    Joe
    27ft 17K gallon Polytech aluminum & stainless AG Pool / DE filter / Wedding Cake Steps
  1. Air Line
    By ts8181 in forum Pool Equipment & Operations
    Last Post: 10-03-2011, 09:55 AM
  2. Help - algae nightmare - drain or bbb, filter & scrub
    By gmcigw in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-05-2011, 05:14 PM
  3. Removing Scum -limit suntan lotion?
    By webfeet in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-22-2007, 03:04 PM
  4. Scum?
    By KatieD in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-07-2006, 10:15 PM
  5. Straps Under Line
    By kanane in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2006, 09:57 PM
