Thread: New build - need equipment help please
    Jul 2014
    Raleigh, NC
    Default New build - need equipment help please
    16 x 36 fiberglass rectangle - 18k gallons
    3 returns - 1 skimmer, no floor drains
    2 inch rigid PVC plumbing
    1 18 inch waterfall - may add another
    PLM150 Pentair PLM Series Cartridge Filter (150 sq ft)
    Omnilogic automation
    considering the T-Cell-15 but not sure due to travertine coping
    With the omnilogic, Hayward told me I have two choices. The Tristar SP3202ND or the Ecostar SP3400VSP. I would choose the Tristar because I think the Ecostar is way more pump than I need, but the Ecostar is the only Omnilogic compatible pump with it own controls in case the Omnilogic is on the fritz. I don't want to be without ability to filter the pool if the automation glitches.
    I plan to add on the aqua comfort ACT-1250 Heat/Cool pump in short order.
    The install is second week in June and I have to finalize equipment choices asap.
    Does anyone have any feedback on selections and how the filter and pump will match up for optimum filtering?
    Thanks guys.
    Jul 2013
    Northern Illinois
    Default Re: New build - need equipment help please
    Ugh. Wish I could help!
    mas985's Avatar
    Pleasanton, CA
    I would double the size of your filter. You won't be sorry.
    Also, did they tell you that the MaxFlo VS would not work with the OmniLogic?
    Also the Tristar comes in a version that has the builtin timers as well if you want to go that route.
    Mark
  1. Help with elevation and build
    By rmclain73 in forum In-Ground Pool Construction and Repair
    Last Post: 07-15-2014, 11:34 AM
  2. New Pool build
    By Usilpool in forum Dealing with Alkalinity and Calcium
    Last Post: 06-23-2014, 10:08 AM
  3. My Build
    By vinper in forum In-Ground Pool Construction and Repair
    Last Post: 07-27-2011, 04:25 PM
  4. Should I Build or Not
    By Omer61 in forum In-Ground Pool Construction and Repair
    Last Post: 08-20-2006, 02:06 PM
  5. If I were to build my own Pool, I would use the following equipment???
    By divnkd101 in forum Pool Equipment & Operations
    Last Post: 08-01-2006, 01:08 AM
