Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Odds-n-Ends (P)
Clearance
--cleanup--
water hardness
If this is your first visit, be sure to check out the
FAQ
by clicking the link above. You may have to
register
before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Results 1 to 1 of 1
Thread:
water hardness
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Linear Mode
Switch to Hybrid Mode
Switch to Threaded Mode
05-17-2015
06:09 PM
#1
kimble jones
View Profile
View Forum Posts
Junior Member
May 2015
america
water hardness
What do you do when your water hardness is low?
Quick Navigation
--cleanup--
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Notes and News from the PoolDoc
Forum Q & A
-- Subscriber Posts --
Pool Water: Treatment, Testing & Problems (P)
Pool Chemistry for Intex-type Pools
Testing and Adjusting Pool Water Chemistry
Using Chlorine and Chlorinating Chemicals
Salt Generators (SWCG) & other Chlorine Feeders
Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
Dealing with Alkalinity and Calcium
Dealing with Algae & Slime
Pool Chemicals & Pool Water Problems
DPD-FAS based testing
Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
Pool Construction, Equipment, Operations, Seasonal Care (P)
Intex-type Pool Setup & Operations
In-Ground Pool Construction and Repair
Above-Ground Pool Construction & Repair
Pool Equipment & Operations
Pool Startup, Shutdown, & Winter Operation
Pool Cleaning: Manual or Automatic
Pool Electronics
Pools, Pets and Creepy Critters
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
need stain help bad!!
green but clear?
Using test kit for water hardness
By rlanthony@excite.com in forum General Interest
5
Last Post:
12-04-2007,
11:22 PM
OH (Ohio) Water Hardness/ph -- Adding chems while filling?
By rydeacowboi in forum Testing and Adjusting Pool Water Chemistry
1
Last Post:
06-02-2007,
07:17 PM
Water Hardness 498
By Phillbo in forum Testing and Adjusting Pool Water Chemistry
7
Last Post:
05-11-2007,
07:11 PM
Who is correct: Water hardness test
By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
1
Last Post:
07-08-2006,
12:21 AM
Water hardness?
By HAYMAN in forum Pool Chemicals & Pool Water Problems
1
Last Post:
06-18-2006,
12:05 AM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
Forum Rules
