Thread: TEST results - above ground pool - Advice please
    Default Re: TEST results - above ground pool - Advice please
    Numbers look good. You need to shock to get rid of the CC (10 ppm FC) and keep an eye on your FC until you get about 30 ppm in the pool from the trichlor tabs. Use bleach to keep the chlorine level at about 2-3 ppm until the CYA builds up some more. Adding the baking soda to get the alk up should raise the pH slightly also but retest both pH and ALK about 48 hours after you add it and reajust the pH if necessary to between 7.2 and 7.6
    THANKS ......I really appreciate the advice.....
  1. In-ground pool construction - looking for advice
    By Northeaster in forum In-Ground Pool Construction and Repair
    Last Post: 08-29-2012, 11:25 AM
  2. Newbie needs advice interpreting first test results
    By laughingboy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2010, 10:30 PM
  3. Need advice, Buying a used Above Ground Pool?
    By philamom in forum Above-Ground Pool Construction & Repair
    Last Post: 08-16-2006, 10:03 AM
  4. your advice needed for test results
    By DMand in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-29-2006, 11:15 AM
  5. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 01:48 PM
