Thread: Best metal sequestering agent?
    Jun 2014
    Nashville
    Default Best metal sequestering agent?
    There is Magenta stuff, Purple stuff, Pink stuff and blue.. etc. For copper at 0.2 and mostly everything else is fine with salt at 3400. What would be good to maintain the copper. When I opened it on day 1 by day 9 it is clear and crystal. Now it is getting stains again. I cannot drain the pool all the way and maybe just a metal sequestering agent will do. Which one do I need?
    18 x 36 Liner Pool. About 1975 built in ground
    22,000 gallon, Hayward/ Jacuzzi Sand Filter
    Aqua pure Salt Water Generator, Chlorine Tab Dispenser
    1Hp super Pump
    Sep 2014
    Tucson, AZ
    Default Re: Best metal sequestering agent?
    Metal sequestering agents will not remove metal stains on their own. If they are metal stains (I answered your other post by the way), then you will need to perform an ascorbic acid treatment prior to adding any sequestrant in order to dissolve the metal stains back into the pool water. Metal stains are precipitated metal salts on the liner material, so you first need to redissolve the metal salts and then use a sequestering agent to help keep the metal ions in solution.
  1. Ascorbic acid treatment for stains, which sequestering agent to use?
    By MountainStone in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-10-2012, 08:33 PM
  2. Well Water: Why you DON'T shock BEFORE using Sequestering Agent
    By NWMNMom in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-09-2006, 05:27 PM
  3. Yes/No: Sequestering Agent. Switching from Pristine Blue to BBB.
    By les_smith in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-05-2006, 10:10 PM
  4. Should I use sequestering agent?
    By Amir in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-05-2006, 03:42 PM
  5. Sequestering agent
    By zelmo in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2006, 12:06 PM
