Re: Metal in the water (Fiberglass 35K pool)
Adding polyquat is a good idea, especially if you live in a hot climate. I don't usually add any, and I haven't gotten any algae after a treatment. The polyquat won't hurt the treatment at all. The first time I did a treatment my water was like milk also. I had a lot of stain - the whole pool was stained. The water will clear up, but if you want to, you can try flock. When I had the very milky water, on the 4th day I used flock in my pool. It cleared up the water. I put it in and waited 24 hours, then I vacuumed to waste. It did a great job of clearing my water, and I didn't get any stain back. I did add more sequesterant after I used fill water (from vacuuming to waste). If the stain is all gone, then doing the flock now won't hurt. You don't want to do it if you still need to get stain off. I can understand that you want to have the pool ready to swim in - and no one wants to swim in a cloudy pool.
Northeast PA
