Results 1 to 10 of 46
Thread: Metal in the water (Fiberglass 35K pool)
    mbar's Avatar
    Ashland, PA
    Default Re: Metal in the water (Fiberglass 35K pool)
    The water is cloudy from the metals going back into solution and the sequesterant - it will clear up, don't worry. I would not start chlroine until tomorrow. Then add enough to get you to 1 to 2ppms. You will need a lot of borax, because the ascorbic acid will take your ph way down. Check it, put in a half a box and test 2 hours later. Keep doing that until you get to 7.2. Don't bring your ph higher than 7.2 for now. Keep your filter running 24/7. Test your alkalinity - if it is low you can use baking soda as well.
    Northeast PA
    Checked the water today, it is about 40 hours after Ascorbic Acid was added.
    Very cloudy (like milk) Bumped the pump, because pressure was at 35.
    Chlorine 0
    Ph 7.2 (for some reason it didn't go down as much as I thought it would)
    It was at 7.5 when I started adding the Ascorbic Acid
    Didn't add any Chlorine yet.
    Marie is definitely the expert on this mater in my opinion and you are in excellent hands. Something I do when going through an "ascorbic acid treatment" is add some 60% polyquat algaecide. You can get it for under $20 at the local pool store, Home depot or Lowes. This gives me a little peace of mind and I don't know if it attacks the ascorbic acid or not (Marie?). My treatments seam to work like a charm (thanks once again Marie! )
    The cloudy "like milk" water is something I've never personally experienced. It may be normal but just out of curiosity, what is your CH (calcium) level?
    Dave
    16K gallon Fiberglass
    My Calcium was at 120-130. Alk was at 80-90
    Well that pretty much shoots my "high CH theory" out of the water. Both of those look fine. Maybe it's the metal, scale or gunk. I'd just keep the filter going, bumping as little as possible.
    Dave
    I got a DE filter EC-75, I bumped 5 times slow down and quick up. Why bumping as little as possib.?
    Because bumping causes the DE and "stuff" to loosen up and it may very well cause some of the "stuff" ( which is hopefully the metal in your case) to go back into the pool. Now this is only my theory but seems logical?
    A couple of days after I do "the treatment", I always change the DE and I also have the EC-75, which I love by the way. The only time I change DE is when doing the "ascorbic treatment", which is usually a couple of times a year. I buy a 21 lb box of DE before opening and it last all season as the filter holds 7 lbs.
    Dave
  1. Metal Stain Treatment + (Combined) Chorine = Pea Soup Green Pool Water
    By ChuckDavis in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-13-2013, 06:08 PM
  2. New Pool Owner 15X42 Intex Metal Frame - very rusty brown well water
    By Heidi B in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-03-2012, 01:41 PM
  3. Looking for concise help with clearing up brown-metal rich pool water
    By bsullivan in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-02-2012, 11:52 AM
  4. First pool, water is clear but fiberglass is stained and lots of scale
    By MountainStone in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-15-2012, 11:14 PM
  5. Just painted my old 45 year old fiberglass pool and refilled with well water.
    By gwingard in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-13-2011, 01:00 PM
