Quote Originally Posted by rdefino View Post
Thanks.
i'll look at getting some Combined chloramines test strips and borates test strips.
Is "Natural Chemistry Liquid Swimming Pool Stabilizer and Conditioner" a good stabilizer to use. I know it was mentioned to used powered since it's cheaper.
Any recommendations for powdered stabilizer?
thanks
Most test strips are useless, very inaccurate. The only test kit you need for your pool is a Taylor K-2006. It tests all the water parameters you need including CC's.
LaMotte InstaTest borate test strips are ok for testing borate levels. They're not as good as drop tests by Hanna Instruments but those tests are expensive and for boron levels in water much less than what you find in pools. So go with the strips for borates.
As far as stabilizer/conditioner/etc (CYA), I'd advise against liquid forms. It's much more expensive and they usually only provide ~ 30% CYA as the solubility of CYA in liquid form is limited. I use BioGuard Maintain-100 Stabilizer (100% CYA) in 6lbs bottles. You can get it a Patio Pools, online or in other pool stores. 6 lbs is more than enough for a adjustment during the swim season.
