Closed Thread
Thread: Flow reversal heating ??? Does it work?
    Default Re: Flow reversal heating ??? Does it work?
    Biggest drawbacks to reverse flow systems is that they usually require automated valves to change the flow pattern to reverse for heating and normal for effecient cleaning and filtering. IMHO, they are not worth the expense for a possible slight increase in heating efficiency. If the pool is already plumbed with an in floor cleaner it will accomplish basically the same thing but I don't think much of in floor cleaners either because of the strain the place on the plumbing system
    Green Bay, WI
    Expanding on what I had said above, it can't be more efficient. Heating 20,000 gallons of water will take x number BTU's no matter if you heat it from the bottom or middle to side or top. Heat is heat.
    Actually your heater itself will be more efficient as the temperature of the incoming water is lower. So let’s just say you do have a thermocline in your pool and it is 85F at the top and 80F at the bottom. If you heat that 80F water it will extract more heat as it passes through the heater then it would if it were entering at 85F. Of course if you increase the flow though the heater as well you would extract more heat.
    Again to heat a 84F pool to 85F it won’t matter where the heat enters, from the sun, a bit from the air or from a heater. As long as it is properly circulated it will take the same amount of heat to heat it up.
Closed Thread
  1. Pump Motor Spade Reversal..UHOH
    By simsjim in forum Pool Equipment & Operations
    Last Post: 05-23-2007, 08:21 AM
  2. Solar Heating
    By badutahboy in forum Above-Ground Pool Construction & Repair
    Last Post: 04-08-2007, 11:38 AM
  3. Design flow rate vs maximum flow rate...
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 06:50 AM
  4. Heating Options
    By Simmons99 in forum Pool Equipment & Operations
    Last Post: 05-20-2006, 12:45 AM
  5. Solar Heating
    By AprilRose in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2006, 01:41 PM
