Results 1 to 10 of 39
Thread: I am planning on replacing my pump, pretty sure its too big
    leena is offline Registered+ Thread Analyst leena 0
    May 2012
    North GA
    Default Re: I am planning on replacing my pump, pretty sure its too big
    how do I upload pics here
    24 round 12-14K gal AG vinyl pool; chlorine tabs and bleach; 300lb Hayward sand filter; Hayward 1 HP 2-speed pump; K-2006
    May 2012
    North GA
    down at the bottom where is says posting permissions.....mine says I may not post attachments. Is there something I need to do to be allowed to post pics?
    May 2012
    North GA
    while I am waiting to find out how to post a pic, Here is a combo I found on amazon. Its Hayward and a 2 speed pump. Is this something that would work for me? On high I think the pump is still 1.5hp which I do not feel I need but couldn't find a smaller 2 speed pump/filter combo.
    http://www.amazon.com/dp/B00CG4EDW4/...I3NHVZOKQHTCLG
    May 2012
    North GA
    Here is another combo, also a 2 speed pump, also a Hayward but with a larger sand filter....21" versus the 18" above. This confuses me as before we talked of sand filters as being 200lbs, etc so not sure why it tell the inches rather than lbs of sand? Im assuming I want my sand filter to be the correct size for my pump or do I go by the size of my pool?
    http://www.amazon.com/dp/B002HHM020/...P89FGH0U&psc=1
    May 2012
    North GA
    now here are 2 pumps that are 2 speed and only 1hp so would this be better? Would that mean on low it would only be 1/2hp? One is a Hayward for approx. $275 the other is Blue Wave for approx. $175. IS the Hayward better quality or are they practically the same thing?
    http://www.amazon.com/dp/B00212NNU4/...=IPBL5VSUIDVO8
    http://www.amazon.com/dp/B00ITPPS6E/...P8VM63AB&psc=1
    Sep 2014
    Tucson, AZ
    Hi @leena, glad to hear back from you! Lots of posts to answer, so here's a synopsis -
    Posting Pictures
    Use a photo sharing service like Photobucket or Picasa. Both of those services are free with lots of upload space. Once you upload a photo, it is assigned an IMG link (which looks a lot like an "http://" link). You can then cut & paste that link in any forum thread and the picture will automatically be displayed in your posts. Trying to attach photos using the Pool Forum's vBulletin software is a waste of time. Since this forum runs on a server with limited storage capacity, users just can't be given a lot of storage space or else the forum will crash.
    Sand Filters
    I am no expert so all I can offer you is this advice - bigger is ALWAYS better when it comes to sand filters. The last thing you want to do is try to run an undersized sand filter with an overpowered pump. Sand filters are describe either by their full sand weight (pounds of sand) or the diameter of the filters "belly" measured in inches. Either way, the bigger the number, the more water flow you get. So your best best bet is to get the largest size sand filter you can reasonably afford. A bigger sand filter always means longer times between cleaning. So if you don't want to backwash a lot, bigger is better.
    Pump
    Definitely get a 2-speed pump, 1.5HP sounds like it would be more than enough for your pool. The two speed option is desirable because sand filters actually perform better (finer particulate filtration) at lower speeds. So for everyday water circulation you can use the low speed setting and get good energy savings and great filtration. Then, when you need to vacuum or run a robotic cleaner, you can kick it up to high speed for fast vacuuming.
    Vendors
    Look, Hayward is the biggest name out there. I don't know of anyone who went with Hayward filtration products and hated it. There are other vendors (Pentair, etc) but if you're happy with Hayward, then stick with it.
    Sorry I can't be more specific, but I am a DE filter guy so my knowledge on sand filters is limited. You could always call up the Hayward technical support people (I hear they are very helpful) and give them some pool details. They may be able to give you lots of different combinations and options to work with.
    May 2012
    North GA
    thanks for the replies!sorry for so many questions at once:/
    So if I have a 1.5hp pump, when Im runnin it on low does that make it the equivalent of a 3/4hp while on low?
    If so, Im thinking I need to get a 1hp so that when Im running it on low its the equivalent of 1/2.......
    Sep 2014
    Tucson, AZ
    Quote Originally Posted by leena View Post
    It doesn't quite work that way. For a 2-speed pump, the low speed is typically 1750RPM and the high speed is typically 3450RPM. While those numbers are roughly 1/2 one another, that doesn't necessarily equate to a pumps power consumption (horsepower) being half. For example, I have a variable speed pump and a control system that lets me set the RPM value and then reports back how many watts of power the pump is using. When I set the pump RPM's to half the max speed, it does not use half the amount of power at high speed.
    May 2012
    North GA
    hmmm, not sure if I understand that for sure but I think from what I've read that I should go with the 2speed 1hp. Ok, I didn't find a combo set with a 2 speed 1 hp so I guess I will be buying my sand filter separate. So from what you said about a bigger sand filter being good, it should be ok to go back with a 200lb filter even though Im dropping down to a smaller pump?
    Ok, that being said, is there such a thing as low quality sand filters? if Im getting a Hayward pump should I go ahead I get a Hayward sand filter?
    Im sorry I realize that's 3 questions but they are all pertaining to the sand filter so kinda same subject, lol
  1. Planning a pool in Dallas. Planning questions.
    By mmcaleer in forum In-Ground Pool Construction and Repair
    Last Post: 09-16-2012, 09:54 AM
  2. Replacing Pump
    By ttgivencej in forum Pool Equipment & Operations
    Last Post: 07-18-2010, 03:06 AM
  3. Spa Chemistry??? Pretty Please!
    By oldAGE in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 11-16-2007, 11:51 AM
  4. CYA test is pretty subjective, isn't it?
    By BillyBumbler in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2006, 03:09 AM
  5. First test of the season, looks pretty good?
    By Crispyc21 in forum DPD-FAS based testing
    Last Post: 04-16-2006, 09:09 PM
