Not sure why you would want a remote. I just trow it in the pool and press on and it works. It stops when its full or after 3 hours I believe. When I come back later I just press on again to restart it for another round if needed.
Easier to haul and install that a 50 ft hose and cleaner.
Keep it simple.
What I like over the pump type is I could never leave the crawler running unattended as the pump will run dry when the filter become clog when the cleaner as pickup some dirts or leaves and plugged.
Or gets jammed in a corner just after I left. If the robots gets jammed it just start backward to release itself. Great unit.
