Pam, Your alkalinity is very high. That's what is making it difficult to get your pH down. Your high pH is probably limiting the effectiveness of your chlorine and that may well be contributing to your difficulty with killing the algae.
I'd get the pH down (no matter how much acid that takes), keep your chlorine at shock levels, and have patience. You can lower the alkalinity once the algae problem is resolved.
Best of luck.
