Results 1 to 10 of 41
Thread: A picture is worth a thousand words . . .
    Downingtown, PA
    Default Re: A picture is worth a thousand words . . .
    There are two issues (kinda one) I see here. The pH is WAY to high, there has been discussion here about how Chlorine is far less effective at high pHs. Second, the TA is too high. Is a 1/4 drain and re-fill possible? Otherwise I would search the posts here for lowering the TA (I believe using aeration) and then brining the pH in line as well. That high pH is effectively shielding the chlorine from working.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    Pamsel is offline Registered+ Thread Analyst Pamsel 0
    Central Illinois
    Well, I guess I'm confused. I was told to concentrate on the CL/algae first and then work on the TA & PH. I have been adding muriatic acid every few days with aeration, but not daily since I was working on algae first.
    The levels I posted were my reading this morning. I meant that I am keeping the Cl about 15 . . . can't be exact because I am doing the dilute/multiply method and I can't tell color shades exactly. Last add was 10:00 pm last night - 4 gallons.
    Have added a total of 3.75# granulated CYA in the past 7-9 days. First add I did with a knee-high hung in front of my return jet and second dose I put in the skimmer. Both times it seemed to dissipate very rapidly. (I've read somewhere here that it should take several days to dissolve?) I have backwashed a few times since then, so maybe I've flushed it out?
    I will go re-test and post up-to-the-minute results shortly. :-)
    Pam, Illinois
    "17'x33' oval 14.5K gal IG vinyl pool; liquid chlorine; Hayward Pro Series, M-S-244T sand filter; A.O. Smith Centurian, Switchless, 1.40 HP pump; Right now 24/7hrs; Pool Solutions PS234
    Serial #6511, Drops / Powder; Community well; summer: none; winter: mesh; ; PF:8.3"
    Downingtown, PA
    Pam,
    Hold off on adding the CYA till last, you want that chlorine as 'unihibited' as possible. If you are currently working a plan of attack recommended by members here then continue that. I only wanted to point out that a high pH will inhibit what you are trying to do.
    Central Illinois
    Here are current test results:
    CL ~ 10-12 (again, I have trouble being sure of shading with dilute/multiply method) Will add another 2 gal CL right now, to get back up to 15
    PH ~ 8.0 (I added 12 oz acid about an hour ago) How frequently should I add acid?
    TA ~ 430 Will this come down once the PH is in line?
    CYA ~ 40 (had already added second dose a couple of days ago)
    I am running filter 24/7 and have been aerating 24/7 for past few days
    Pam, Illinois
    Sanford, FL
    Quote Originally Posted by Pamsel
    PH ~ 8.0 (I added 12 oz acid about an hour ago) How frequently should I add acid? Careful here - is sounds like you have a test kit that is not able to handle high chlorine levels (over 10ppm) It may be giving you a false high reading. Test this again when your chlorine levels are below 10ppm.
    Have you had your water tested for copper? It seems to have a really "pretty clear" green to it.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Central Illinois
    Yes, it was tested on Friday. Copper was .2. Pool store said that wasn't significant. Is it?
    Pam, Illinois
    Sanford, FL
    Try private messaging mbar - personally I think you could have copper suspended in the water giving it the green look - but mbar can verify. You can try a sequestering agent for copper.
    Copper tends to suspend in high chlorine levels. Have you used a copper algecide or used a source of water that may have metals (like well water)?
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
  1. How would you backfill this (picture included)
    By idohair2 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-27-2011, 10:43 AM
  2. Pool Planning Picture - Feedback sought
    By skijunkie in forum In-Ground Pool Construction and Repair
    Last Post: 03-02-2011, 02:47 PM
  3. Where to blow out line (picture)
    By Charrua2 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-10-2006, 05:08 PM
  4. words of encouragment!
    By ILHoz in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-21-2006, 11:03 AM
  5. Picture of S 244T Hayward Valve Control?
    By LennPrice in forum Pool Equipment & Operations
    Last Post: 07-05-2006, 09:09 PM
