Thread: Green chewinggum like residue on sides of spa after using cleaning chemical
    Default Green chewinggum like residue on sides of spa after using cleaning chemical
    Following the use of SeaKlear System Flush I am left with a green and very sticky chewing gum like residue on sides of spa. This is very hard to remove and what little I have so far removed was done by using a paint scraper and then holding an acetone soaked rag against the remaining residue. Acetone is probably not the best choice for abs plastic but is the only thing I have found so far that will dissolve this residue. Even with that I still need a lot of elbow grease
    along with it. Any ideas as to what this residue might be? I am hoping it isn't grease from some bearings, but then grease is, well, greasy and slippery whereas this stuff is literally like extra sticky gum. Any suggestions as to how remove it without damage to the spa shell would be appreciated.
    Anonymous [GDPR] European in the UK Guest
    Default Re: Green chewinggum like residue on sides of spa after using cleaning chemical
    I had something similar on a customers pool, the pool company (EX pool company) poured two 1 litre bottles of flocculent into the pool, I don't know what make but could have been seaklear. I had too strip and clean everything even the prefilter was solid with goo which I described as liquid chewing gum, emptied the large sand filter cleaned and changed the media, what a mess.
    Jul 2013
    Northern Illinois
    Yuck
    Angry Re: Green chewinggum like residue on sides of spa after using cleaning chemical
    That is similar to what I said
    Jul 2013
    Northern Illinois
    Tried to find an older thread to contact you, Teapot. Can you take a look at this thread? http://www.poolforum.com/pf2/showthr...870#post130870
  1. Do sand filters need chemical cleaning?
    By Pappy in forum -- Subscriber Posts --
    Last Post: 08-24-2014, 07:24 PM
  2. SWCG Pool Opening - green water - brown stains - chemical fixes?
    By MRollinson in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-05-2012, 10:36 PM
  3. What is this residue and how do I get rid of it?
    By swimmy in forum Dealing with Algae & Slime
    Last Post: 07-03-2006, 10:52 PM
  4. pool green - chemical imbalance?
    By roadrunner in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-02-2006, 01:38 PM
